Does anyone out there know how to dial in the tailstock of these lathes? I have a .004 taper between centers in 12in. of travel. The manual doesn't say anything about adjustment. Thanks ahead of time.
Another Day in Paradise
Does the tailstock have jackscrews one directly across from the other, down towards the base, make sure that you don't have the tailstock locked down when you adjust as this will break the slide, it should work as a push pull. let me know if this works. I will look at ours tomorrow. good luck. minard
