585,991 active members*
6,409 visitors online*
Results 1 to 8 of 8
    Aug 2004
    210
    Best Desgin software ????
    What is the Best Desgin software out thare to use on a home made cnc router and i am also looking for good software to send the code to the machne i like easy to use and powerfull software
    THanks
    Mar 2004
    1806
    I am not sure what you mean by "Best Design software", But I draw in autocad, export as a dxf file, run it through Sheetcam (now in beta) www.sheetcam.com , to generate the gcode and then use TurboCNC www.dakeng.com as my controler.
    To me, this is a powerful setup and for ME, it is easy to use.
    I use autocad as I have it for work.
    Sheetcam is extremely easy to use (and I might add generates good code time in and time out)
    Turbocad is dos based, easy to use does the job and not overly priced.
    Of course YMMV, but I am satisfied with this setup.
    Bubba
    779
    I use SolidWorks 2004 design software. MasterCam 9.1 to generate code. Mach 2 to run it.
    That is a powerful setup for home use.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    What type of parts (objects?) are you designing?
    Aug 2004
    210
    Quote Originally Posted by ger21
    i want to make wood stuff like clocks and tables stuff like that
    Any inexpensive CAD program, like DesignCAD or TurboCAD should do fine.
    May 2004
    50
    topsolid
    I saw on tool show Topsolid it looks very promissing but it will not fit your buget.
    Aug 2004
    210
    what about bobcad v19 is that a good start ???
  1. Engraving Software
    By The Wizard in forum Uncategorised CAM Discussion
    Last Post: 03-29-2005, 12:38 PM
  2. Software sales or "license transfers"
    By metlmunchr in forum BobCad-Cam
    Last Post: 07-05-2004, 10:47 PM
  3. ***One stop CNC software guide***
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-27-2004, 10:31 PM
