585,722 active members*
4,184 visitors online*
Results 1 to 6 of 6
    Jan 2006
    387
    Router Bit Changes
    OK folks, I need some input.
    I tend to limit what I cut on the CNC machine due to bit changes being difficult and often moving things out of index. I'd love to be able to rough out a piece with a big ball end and then finish it with a nice fine detail bit, but I end up doing it all with one bit because changing the bit on my router ( it's currently a Bosch Colt ) is a real pain in the a$$.
    So, for my new machine, a Solsylva belt-drive homebuilt that I just finished all the parts for and am about three days from cutting with, I have a PC 690 router with an outboard speed control that I plan on using.
    Now, I see on chipsfly.com a replacement collet that makes bit changing a simple matter of a single setscrew that tightens a ring around the collet. That's a great idea even if they don't make a quarter-inch version.
    BUT- and there's always a but- if I go that route, I'd have a half-inch collet with a quarter-inch reducer holding an eighth-inch reducer for use with the Precisebits.com 8th-inch shank bits. That's a lotta runout potential if you ask me.
    So I see Ron's got some nice precision collets for use with the small bits. Ooh! I want!
    BUT- another but- this wont' address my issue of bit changes being a b*tch. ( Isn't it interesting that the first 5 letters of the phrase 'bit change' describe the process perfectly?)
    So, anyone got any suggestions on how I can make bit changes easier? Should I forget the idea of a quick-change quarter-inch collet with a reducer for the 8th inch bits ? I need some input on how much runout these quick-change collets introduce, and what my options are- I've only ever seen the one quick-change collet, are there others that might work? Where do I look?
    Help me Obi-Wan, you're my only hope.
    Jan 2006
    387
    OK, I guess no one else ever changes bits on a router in the middle of a cut file.
    Feb 2004
    361
    sure, I align to a set reference plate, others use 'find zero' type of functions...
    some just make up their own set screw collars, and use an indexing station..
    on a wood router it's not that big of a deal, as compared to a precision metal mill...
    ..enjoy..
    http://www.sears.com/shc/s/p_10153_1...seBVCookie=Yes
    apparently you can get these for porter cable
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Apr 2005
    438
    My router is belt driven and I also moved the axis sometimes when I was changing bits.
    After picking up the collet set from Think & Tinker I found it is much easier to change bits, Securing the bits takes a lot less force versus the standard PC collet. I no longer get the “snap” which caused me to move the axis when the nut breaks lose. A big plus is the ability to use 1/8 bits on my 892..
    Jan 2006
    387
    I definitely plan on getting that collet set, no question. Guess that's the way forward, unless I want to pay 2800 bucks for the ATC I saw using a 7518.
  1. Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 01:51 PM
  2. Does anyone own a EZ Router Machine? Plasma or Router.
    By sngatlanta in forum Commercial CNC Wood Routers
    Last Post: 04-11-2008, 04:48 PM
  3. Router Using 3/4" MDF (first router build)
    By eguy208 in forum CNC Wood Router Project Log
    Last Post: 04-11-2008, 04:33 PM
  4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
