585,949 active members*
4,068 visitors online*
Results 1 to 1 of 1
    Aug 2008
    router trimming
    hello cnczone
    need carbon composite parts trimmed of flashing. These are small parts with 1mm thick material. The flashing has been designed to help with fixturing, cutting squares into a sheet of just 3/8 in hdpe would keep parts aligned. Looking to have 30-40 sets machined in 2-3 weeks. Will obviously supply parts.
    Attached Files Attached Files
  1. CUTTING OR TRIMMING SURFACES
    By nogginkj in forum OneCNC
    Last Post: 01-02-2008, 08:33 PM
  2. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
  3. Trimming parts in assembly
    By Capgama in forum Solidworks
    Last Post: 09-19-2006, 03:49 PM
  4. Trimming in bobcad
    By Parameter in forum BobCad-Cam
    Last Post: 12-30-2005, 10:07 PM
