585,930 active members*
4,113 visitors online*
Thread: cnc network
Results 1 to 6 of 6
    Oct 2004
    cnc network
    Hello to all:
    I am trying to establish a network among my cncs using a 10t hub( network adapter). I have 12 cncs and 4 computers hooked up to an rs232 data switch (ABCD). Every time I send or receive a program, I must manually hook up the cable to the proper cnc machine. You can imagine my weekly mileage.
    Does any one know how to wire this thing so that I can create a network.
    An schematic would be highly appreciated.
    In advance, Thanks a bunch.
    Mar 2004
    1661
    Check out http://www.bsdhome.com/comserv/
    We used to have a Minix (small Unix-clone, similar to BSD) with 12 RS232 connectors and it was working as a switch for the CNC's, the only thing the operator had to do was to drop the file to be transmitted in the folder for the specific machine. I can't remember the name of the software but it should be possible to create a program for com port handling pretty easily with Linux with similar functionality.
    --Sven
    Mar 2004
    190
    The logic is, as svenakela said, to use a 'smart hub' and a linux is a good solution. To put at work lot of rs232, that can be a little bit hard to manage in the sense of irq's and similar, you can use the kind of multiple line cards that where used for modem pools, they are cheap now.
    Nov 2003
    459
    I hate RS232 stuff, I wish it would go away!
    No, really I just hate the waste of time that this stuff ends up taking...
    I know your pain though, with that many CNC machines you've got to have enough justification to have this done for you.
    I'd recommend Predator...
    They will come in and wire it up for you and you won't have to deal with it...
    Scott_bob
    Oct 2004
    Thanks for all the input.
    Apr 2004
    678
    If what you want to do is replace the RS232 cabling with UTP/Cat5 Ethernet cabling, this box: http://www.ethernetip.de/products.htm#HILSCHER may be what you're looking for.
    In USA you should call: (+1) 630-836-8679 Ask for Phil Marshall (Sales) or Tobias Klebert (Technical)
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Making money with CNC
    By Johnuk in forum Community Club House
    Last Post: 12-13-2009, 05:46 PM
  3. Beginners CNC Advice
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:10 PM
  4. Newbie to CNC world
    By HighOctane in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 08:58 PM
  5. The start of a big CNC project...
    Last Post: 09-30-2004, 11:34 PM
