585,875 active members*
4,084 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Anybody ever milled hard plaster?
Results 1 to 13 of 13
    Question Anybody ever milled hard plaster?
    I have a potential client asking if I can mill hard plaster for some type of relief plaque. The pieces are about 12 inches in diameter. I have a TM-1 and even with the dust collection system I have, I'm afraid the plater dust would get into everything. I also have no idea what type of tooling would be best.
    Anybody ever tried to cut plaster?
    I am asking the client if I could substitute alu or some type of plastic instead of plaster. Otherwise I'm tending to decline the project.
    I'd appreciate any tips anyone might have to offer!
    www.wilkins-knives.com
    Jul 2005
    12177
    Decline would be my approach.
    You are talking gypsum plaster, plaster of Paris, the stuff used in wallboard?
    Very dusty, very abrasive. I have done it on manual machines but I would be very reluctant to put in on a CNC, especially one with exposed guides like a TM.
    Sep 2003
    1113
    Offer to make him a master from another material and then encourage him to use that as a buck for a silicone mold --IF he really wants plaster!
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Dec 2005
    1408
    Dear kevin,
    With a diamond-tipped cutter, you should be able to do the work. With excellent dust extraction, your machine may survive. It is , however, not a job I would take on unless you are confident that the dust will not destroy your machine. Angle grinders are built to resist this type of dust, but spindles/routers are not.
    My 2c
    Best wishes,
    Martin
    Thanks guys, that's what I was thinking too. I guess I could say, "For €25,000 I'll do it." :-) I doubt my dust extraction would get all that dust and it would make the job a major money looser.
    I'll pitch the idea of using another material such as alu, if not, I'll suggest looking for a mason!
    i couldn t imagine what that kind of stuff would do to a coolant system ,
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jan 2008
    575
    I machined some material designed as an arc shield for high output limit switches that was similar to dry wall----Murder on the machine, literally, we scraped it when the job was done, (VF-2) and those ways are covered. Robert
    You scrapped a VF-2 after one job! I hope that was a well paying job...
    Feb 2008
    40
    The job ran for about 2 and a half years.
    Jul 2005
    12177
    Quote Originally Posted by littlerob View Post
    Just as a matter of interest how long ago did you do this? My first guess, years ago, about the composition of something used as an arc shield is that it would contain asbestos. Now I don't know what is used.
    Jan 2008
    575
    It was not long ago maybe 5 years, the material was called transite, nothing good about the stuff, I dont know enough about it to say whether the tecnology was modern or not, just that the warning labels persuaded me to wear a respirator all day. I don't think it contained asbestos though.
    Apr 2004
    5737
    There's a product called Rayite
    that's made by USG specifically for machining. I've used it with okay results. After casting it into your rough shape, you need to let it dry thoroughly before cutting it, or its sticky chips will make a big mess (don't ask...)
    But if it's not absolutely necessary to make this directly in plaster, I'd certainly advise cutting it in something more user-friendly, like machinable wax, and casting the plaster in a mold made off that. The wax gets a great surface, and makes an excellent master for molding.
    Modern transite doesn't contain asbestos, but the free silica in it makes it something you want to protect yourself from breathing anyway. It's abrasive too, so you wouldn't want it around your mill, unless you've got a job that will buy you another one...
    Andrew Werby
    www.computersculpture.com
    I passed on the job if it it has to me plaster. I did suggest using another material and the client is checking on that or he may have somebody lined up with a router mill that doesn't care about the dust. He did understand my concerns.
    Thanks to everyone here for your help!
  1. First milled PCB
    By Jason Marsha in forum PCB milling
    Last Post: 11-19-2008, 03:49 AM
  2. Making Plaster mold for casting A356
    By navnav2006 in forum Casting Metals
    Last Post: 08-17-2008, 01:25 PM
  3. I need some slots milled in some 14 ga SS.
    By Jeff Wohlt in forum Employment Opportunity
    Last Post: 10-31-2007, 11:02 PM
  4. Never milled but have a project
    By mikesativa in forum MetalWork Discussion
    Last Post: 03-22-2006, 08:24 PM
  5. Plaster Patterns
    By mtuckf in forum Moldmaking
    Last Post: 05-20-2004, 11:56 PM
