585,737 active members*
4,904 visitors online*
Results 1 to 17 of 17
    Aug 2008
    7
    Hercus PC200 Retrofit
    Hi all,
    First post, so bear with me if this is a little long winded. I have been asked to investigate the viability of resurrecting a Hercus PC200 Lathe that has sat in storage for some time. The original PC and I/O hardware have long since disappeared so I am looking into the possibility of a retrofit and would appreciate some advice.
    The machine runs two Electro-craft E586-SA (586-024-24) servos for the X and Z axis and a SEM (Small Electro Motors) DPM30L2 Motor, 180V 0.37KW 2500RPM 2.3A for the Spindle. The encoders are HP HEDS-5540-I12 units and the PWM boards are proprietary Hercus, as is the main machine interface board.
    I would like to eventually run the machine using MACH Turn and as such re-config the controller and servo drivers to suit. Has anyone any experience in these machines or any of the component parts that could give me some guidance?
    24220
    Do you know if the PWM drives were 10v analogue or step/dir?
    This will probabally influence the fact as to whether you can use them or fit new drives.
    If the motors have tach's you do not need these with modern drives.
    They are 20oz-in 5000rpm motors.
    Al.
    Albert E.
    Aug 2008
    7
    Re: Hercus PC200 Retrofit
    Al, thanks for the reply.
    Sorry, no info available on whether the PWM cards are step/direction or analogue. Hercus have nothing to do with them any more; the most I got from them was "sorry, it won't run without the original I/O controller".
    I have already resigned myself to replacing the drives and this is where I was hoping to get some guidance. Handy to know that the tacho output is irrelevant, any suggestions as to what may work (spindle and axis)?
    The sad part about all this is that when I started investigating the machine, the only issue I could find was a faulty E-Stop!
    24220
    If you are going with Mach etc, you will need step/dir drives, there are plenty of links here for ones to chose from.
    You need to know the resolution and pin out of the encoders also.
    You have most of the info off the SEM spindle, so if you need any more on the servo's I should have it in the Electro-Craft manual.
    The spindle controller could be any small PWM controller, If the spindle motor has a tach, I would look for one that takes a tach feed back as this gives precise speed control of the spindle motor.
    Also I would look into salvaging the existing DC power supplies for both drives and spindle.
    Al.
    Albert E.
    Aug 2008
    7
    Al,
    I have limited info on the servo's so any thing you could provide regarding the electrical caharacteristics would be great.
    No Tacho on the spindle, just an encoder off the gearbox but I have the datasheet for these so thats all good as is the PSU's.
    Thanks again
    24220
    The general info on the E586 I have is:
    continuous torque 29oz-in (not 20 as I previously mentioned)
    Peak before demag 240oz-in
    max voltage 60vdc
    max rpm 6000
    Kt 9.6 oz-in/amp
    arm inductance 3mH
    Tach 14v/1krpm
    There is a bit more info but it is not usually needed for general sizing etc.
    Al.
    Albert E.
    Aug 2008
    7
    Thanks for the info Al, much appreciated.
    Jul 2003
    62
    Hi John
    I also have a Pc200 in storage without a I/O card and would be very interested in being involved
    Aug 2008
    7
    Robwhi,
    This project is still in it's infancy and as such I haven't got a lot to offer just yet. I have done most of the leg work regarding the existing motors, encoders etc. and all appear usable with new drives so I'm now waiting on quotes from a couple of vendors.
    I'm hoping that it should be straight forward; new drives & tuning. I intend keeping the original switchmode PSU and Transformer (replacing the bridge rectifiers, filter caps & fuses which are part of the original interface board). All the remaining hardware checks out OK (statically) so when I get the go ahead to spend some money I'll have more info.
    Jul 2003
    62
    Hi John
    You have got my interest going to get mine up and going as well I will dig it out and start looking at what I can do as well.
    Has your lathe got the toll changer fitted?
    Regards
    Rob
    Aug 2008
    7
    Re Hercus & Tool Changer
    Hey Rob,
    The lathe actually belongs to a local school and I sort of fell into the the task of investigating the possibility of a retrofit, more a case of "while your here....". The lathe is pretty much bare bones, no tool changer. Still waiting on a response from a local vendor regarding pricing, will have to start chasing that up.
    Ian
    Jul 2003
    62
    John
    Mine has the tool changer. I have the origional computer but the I/O card is missing. I will dig mine out on the weekend and see what I can find out and do to get it running as well. I wonder if it can be run with geco drives or similar.
    Al do you know if this is possible?
    Regards
    Rob
    Aug 2008
    7
    Hercus Lathe
    Rob,
    I've been looking at Rutex 2020 and 2010 and Larken Viper 75 and 200 (viper 75 due soon), the spindle supply is 160V, PWM for speed control only and the Axis supplies are approx 40 Volts each (all from the transformer). The switchmode seems to be for ancillary power-cotroller logic etc. If your Servos are the same as posted earlier then you have the max. current, the supply rails are breaker backed, 10A for the spindle and 5A for each axis. I haven't looked into Gecko.
    Ian
    Feb 2006
    Anyone,
    We have a Hercus PC200 lathe and would like to retrofit it. Right now it loses home position. It does have an I/O card and 6 position tool changer. It's useless in its current state and any ideas to get it running correctly would be helpful. I have noticed the HEDs resolvers on the servo motors are silicon sealed on, not exactly state of the art.
    Thanks!
    William R
    Feb 2008
    33
    Hi William,
    If you can explain in a bit more detail exactly what's happening when you 'loose home postiion' I may be able to help.
    Regards,
    Grant
    Nov 2012
    Hi sorry to dredge up an old thread,
    But I have also inherited a PC200 with electronic gremlins
    Was working fine until I moved the machine to new premises
    Now she don't work anymore!
    Checked everything I can think of but think its time for an electronics upgrade.
    She's a manual tool changer model would also like to find a tool changer if anyone has one lying around...
    Mine has the same drives spindles and encoders as listed above has anyone successfully got one running again with the existing drives etc?
    Any recommendations on the best way to go with this machine?
    Jul 2009
    152
    Hi All,
    Sorry to dredge up an old thread, but did anyone get anywere with retrofitting a Hercus CNC lathe - PC200 ? I have been offer one which is not going.
    Rick
  1. Hercus VMC300 help
    By Wegs45 in forum Australia, New Zealand Club House
    Last Post: 03-05-2014, 10:13 AM
  2. Hercus Compulathe retrofit
    By macona in forum Vertical Mill, Lathe Project Log
    Last Post: 01-13-2011, 01:05 PM
  3. Hercus Computurn
    By Doug Baker in forum Australia, New Zealand Club House
    Last Post: 04-16-2009, 04:45 AM
