585,894 active members*
5,043 visitors online*
    Jun 2008
    23
    need help on sense resistor
    My friend gave me a stepper, bipolar rated at 5.3V 8.5ohm (0.625A / phase)
    I use AVR + ST L6219 for controller http://www.st.com/stonline/products/...re/ds/1377.pdf
    I have 0.22ohm 1w resistor then set vref to 1.65v since the formula from datasheet to calculate max current is
    I max = Vref /RS * 10
    = 1.65 / 0.22 * 10
    = 0.75A -> a little bit over current
    then I measure the voltage at RS, it 0.12v
    I=V/R
    = 0.12 / 0.22
    = 0.64A
    Am I on the right track here?
    Is it normal for 0.625A stepper drived by 0.75A controller drain 0.64A ?
    Jul 2008
    411
    Quote Originally Posted by xinzc28 View Post
    = 1.65 / 0.22 * 10
    I=V/R
    = 0.12 / 0.22
    = 0.64A
    The current in the coils is not DC but PWM'd to create the necessary varying drive level to step the motor. Therefore the voltage you measure will be an average voltage (roughly, depending on your meter) but not either the peak or true RMS voltage, (and therefore current) - in other words measuring the sense voltage tells you little about the actual current as its not a static value (except maybe when the motor is stationary). However its clearly in the right ballpark so unless your motor is getting excessively hot I'd be happy with it... but why not set Vref to 1.375v, or chage Rs to 0.27ohm?
    Jun 2008
    23
    Thank you for your comment & advice.
    I'll change vref to 1.375v.
    since there is no problem I'll rebuild the circuit from breadboard to pcb.
  1. Finally, Soft Jaws that Make Sense
    By Team Pierson in forum News Announcements
    Last Post: 04-29-2008, 02:24 AM
  2. no sense of direction
    By joe kilo in forum Mach Software (ArtSoft software)
    Last Post: 04-01-2008, 03:25 AM
  3. Lead on California, even if it makes no sense
    By dynosor in forum Environmental / Alternate Energy
    Last Post: 11-04-2007, 03:37 AM
  4. Does this make sense??
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 12-29-2005, 07:28 AM
  5. Help choosing sense resistor for H bridge
    By Codeman in forum CNC Machine Related Electronics
    Last Post: 08-17-2005, 06:02 AM
