586,000 active members*
4,902 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Cutting parameters with X2 advice needed
    Jun 2008
    475
    What would some of you experts advise as proper cutting parameters such as spindle speed, cutting depth, feedrate, ETC. using a Griz X2 and a 1/4" endmill on the .DXF below ?
    It's 1/4" thick mild steel.
    THX.
    Attached Files Attached Files
    Use about 1500 RPM @ 6-15 IPM with .025 DOC should be OK (it's up to you)
    maybe .010 for a finish pass and some kind of coolant/oil.
    This Calculator is a big help, do the RPM 1st, then the Feed Rate 2nd.
    Surface Speed Ft./Min. figures are in the chart below.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2008
    475
    Thanks for your advice Hoss, I went with 4 ipm (just cautious while still learning) and .025 DOC, ~1500 RPM and that worked very good.
    And thanks also for the link to Online Metal Supply in your ATC thread, I had been looking for a hunk of 6061-T6 at a good price for milling a mold for my injection machine I built recently and they had the perfect size at a fantastic price.
    Steve
  1. T1 parameters NEEDED!
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2015, 01:35 PM
  2. cutting parameters for natural peek
    By fsa in forum Material Machining Solutions
    Last Post: 07-04-2008, 05:30 PM
  3. QT10 chuck barrier data..and parameters needed (YESTERDAY!..help)
    Last Post: 03-05-2008, 10:16 PM
  4. Cutting advice needed
    By ninauk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-27-2006, 12:33 AM
  5. cutting parameters
    By captahab in forum CNC Wire Foam Cutter Machines
    Last Post: 01-16-2006, 05:11 AM
