585,728 active members*
4,240 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Sharing my Haas vector drive schematics
Page 1 of 2 12
Results 1 to 20 of 34
    Mar 2008
    21
    Dear friends
    I saw that every friend in this section of the forum had some problem with the Haas spindle vector drivers. I also had lived problems with this module. My problem had been a huge one; a considerable part of the board had been burnt out. For this reason I had been obligated to draw its electronic schematic diagram all over. Referring to many problems around, I decided to put my schematics for share. However, there may be a few mistakes on the diagrams, so be careful... If you happen to find some problem on it. Please feel free to inform me about it. It shall be fixed as soon as possible. The link is given below.
    http://www.edim.com.tr/index.php?opt...download&cid=3
    Best regards.
    Tayfun Kusluoglu
    Aug 2008
    16
    Real nice of you Tay
    But I am unable to link to that...
    can you check the link again please ??
    MJM
    We have Haas vector drives and sure would like to see what you prepared...
    Nov 2007
    1702
    Wow! Thank you! I really could have used that about a year ago. I learned most of what I now see on that schematic. In the end, it was a problem that was not fixable (bad circuit board) but I spent a lot of time learning what everything did.
    Greg
    Mar 2008
    21
    Thank you ilbebach,
    There was a problem at our host yesterday.
    Would you check again the link?
    There are 15 dowloands performed succesfully.
    I hope you can reach the schematic diagrams after now.
    Best regards
    Mar 2008
    21
    Dear Greg
    Thank you for your kind attention.
    I was ın luck. I could fix my problem. I repaired my pcb board.
    J7 and J5 connectors are too important. Belong to J5 cable side has to never connected to J7.
    So, my friends please be careful. Otherwise, you obliged to repair your pcb.
    Your intensive attentions encouraged me.
    In a near future, I will issue Ingersoll-Rand Compressor control board and Yaskawa USASEM-08TF22 motor encoder electronic schematic diagrams.
    Best regards,
    Tayfun
    Aug 2008
    16
    Yeah I got it ok .
    Thanks again for the schematics .
    regards
    MJM
    Mar 2008
    21
    I am glad to meet you in the forum
    Nov 2011
    5
    Thanks so much!
    We have two VF-5s with 40HP Vector drives. The board isn't exactly the same but it for the most part, and the rest is functionally similar. We had to replace one last year and now the other one has gone down... both at 4 years! Not the most reliable machines...
    Your schematic has been most valuable and the problem is almost pinned down.
    Thank you again!
    Nov 2009
    71
    I have a VF6 and the vector drive on it's way out would it be posible to get a copy of the schematic? It would be most helpfull.
    Eric
    Nov 2009
    71
    Quote Originally Posted by Eric MFG View Post
    Eric
    If I buy another drive it would be the forth that was replaced in 6 or so years!
    Mar 2010
    1852
    Wow, you really have bad luck or have a whole lot of machines.
    Mike
    Nov 2009
    71
    Unfortunately, the drive on the same machine keeps failing. None of the VF3’s have the vector issue but they all have their own unique problems per machine.
    have any of your haas mills had a puddle of spindle fluid laying under the back corner of the machine?
    Haas ended up taking care of our problems.
    Feb 2012
    Thank you for the schematic of the Vector Drive although I have the 40 HP. I had a servo amp blow and the Vector drive unit also. I checked the servo windings and found them all to be with in tolarance. 1.5 ohms between leads and no shorts to ground. Open to ground. AC volts are 120, 240, 120 for the 3 phase. The resistors on top read 5.9 ohms. So I have not been able to find a reason for the unit to have blown the way it has and I want to be sure everything is good before I replace the Vector drive.
    Any thought on what else should be checked?
    May 2012
    67
    I know what causes them to fail. PM me for more info.
    Sep 2009
    75
    Re: Sharing my Haas vector drive schematics
    Hi there,
    Thank you for allowing me to download your 15/20 HP Schematic of the vector drive. Do you happen to have a schematic for the newer style 40 HP Vector Drive? This is the one i am stuck with at the present moment.
    Mine is giving me an error 123 and 993 for some reason and we are not sure why. Can you help?
    Apr 2017
    Tayfunk and others,
    I just ran across your schematic of the Haas Vector Drive while looking for specific information on those drives and while I haven't found what I was looking for yet I thought you or someone else might know and could help. What I am looking for is the connector numbers and pin-out for the VFD controls....ie. Analog in, Run/Stop, CW and CCW controls. I reviewed you schematic, but I didn't see labels that would help me identify which was which. My machine manuals only show these connections in block form and I haven't been able to find any detailed documentation showing the control connections and requirement.
    sccues
    Feb 2012
    115
    Quote Originally Posted by sccues View Post
    Tayfunk and others,
    sccues
    You won't find that because all a vector drive is is an amplifier and high voltage generator. The mocon sends everything in analog for each phase. A simplified explanation is that it is controlled just like another brushless axis.
    Apr 2017
    Quote Originally Posted by erikfriesen View Post
    Thanks for the response. We are converting a machine with a failed processor over to mach4 control. Everything is going well except for confusion over communicating with the haas vector drive. I have the ability to drive the amplifer and motor like another axis through my controller card, but i still don't the pinout for those connection. Does anyone know what pins the analog in and the encoder feedback to the controller fall? If not, do you think my beat option would be to purchased a standard 15hp vfd and just ignore the encoder and control the speed with the 0 to 10v output from my breakout board.
    Thanks again
    Feb 2012
    115
    I'd suggest starting a new thread for this. I sent PM, but not sure it works.
Page 1 of 2 12
  1. haas vector drive 20/15 hp
    By paul emblem in forum Haas Mills
    Last Post: 12-29-2021, 06:00 PM
  2. HAAS Vector drive schematics-
    By jasondeanbarnes in forum CNC Machine Related Electronics
    Last Post: 04-25-2014, 09:39 PM
  3. HAAS VF2 vector spindle drive
    By crococh in forum Haas Mills
    Last Post: 04-03-2010, 03:33 AM
  4. Haas Vector Drive 20/15 Need Help
    By tecko in forum Haas Mills
    Last Post: 02-23-2007, 03:17 AM
  5. Haas Mill, Vector Drive
    By DEAN in forum Haas Mills
    Last Post: 03-17-2005, 11:05 PM
