585,982 active members*
4,541 visitors online*
    Nov 2006
    20
    ez router / thc help
    marcmnrsports
    torch height help
    hi all
    i am really desparate for some help here
    i have an ez router setup, running scribing / engraving, plasma cutting / router
    i have the thc 300 unit and cant seem to get it to work arc start , arc ok both light up anbd work, but torch up down / floating head system does not, when i do cut something the torch gradually creeps down untill it scrapes along the surface, can i disble the height adjustment and just run manually untill i get more parts from ez router to fix my th problems
    many thanks
    marc
    Aug 2011
    Re: ez router / thc help
    hi Marc,
    I realise this is a really old post, but did you get a solution - I am seeing the same problem on my machine. (ez router)
    Geoff
  1. Replies: 7
    Last Post: 10-13-2015, 07:28 PM
  2. Newest CNC router machine from SINICNC-SIN-C3636 Mini cnc router
    By RoseChina in forum News Announcements
    Last Post: 09-16-2013, 07:29 AM
  3. with a Precix Table Router with Perske router
    By SignShop Grunt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2010, 10:08 PM
  4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
