585,605 active members*
3,207 visitors online*
    Sep 2006
    36
    Question Clueless about plasma cutters
    I have a cnc router and I know how that works, but how does a cnc plasma cutter work?
    how does the cnc or Mach 3 tell the plasma cutter when to turn on and off, I can under stand it would be like a cnc router as in x and y, and z determines where cuts will be made, but how does the cnc actualy triger the plasma cutter to fire? is there an extra cord running from the control box to the plasma cutter, do you need a special plasma cutter with a computer hook up?
    Fustrated in Florida
    24220
    Normally there is a contact closure required on the plasma unit, similar to what would be a trigger switch on a manual torch.
    On the more sophisticated tables with high frequency start for example, the initiation will wait for arc transfer to occur before torch movement occurs, if no transfer then the axis movement will not occur.
    Al.
    Albert E.
    Sep 2006
    36
    Oh I get it, the torch and the material geting cut has to be so close together as to create an electrical contact firing the plasma cutter.
    Thanks for the info
    24220
    The torch does not make contact with the work, when the torch is at the correct height above the work piece, an arc is started within the torch called a pilot arc, this arc or plasma effect ionizes the gas or air stream through the torch, this arc then transfers to the work piece and the arc is sustained as long as the high voltage DC is maintained.
    Al.
    Albert E.
  1. Clueless Newbie Design?
    By bigz1 in forum CNC Wood Router Project Log
    Last Post: 04-03-2008, 01:26 AM
  2. Why the big price difference in plasma cutters?
    By schoobie in forum Torchmate
    Last Post: 10-31-2007, 04:01 PM
  3. Clueless in Indy- questions about Allen Bradley servo setup
    By snapman in forum Servo Motors / Drives
    Last Post: 02-15-2007, 05:14 PM
  4. Looking for plasma or waterjet cutters, DIYers too
    By jimboston in forum Employment Opportunity
    Last Post: 06-01-2006, 04:28 PM
  5. Clueless again!
    By widgitmaster in forum Stepper Motors / Drives
    Last Post: 09-30-2005, 11:11 PM
