586,005 active members*
5,181 visitors online*
    Apr 2008
    32
    Emco VMC100 rebuild
    I have an Emco VMC100 cnc mill which has a control cabinet that will not switch on at all . Has anyone managed to convert one of these machines using MACH3 . If so have they managed to workout how to control the spindle speed and also the 10 station tool carousel ?
    Thanks in advance .
    Jul 2007
    59
    whats type is the spindle motor? , not heard of vmc100 conversion yet but i know of two pcmill50's converted, one a close buddy. you can use an inverter for the spindle controlled via its analgue volts input in (if its a 3ph motor) controlled via a spindle speed control card, which itself takes the step and dir signals from mach and convert it into volts etc / 0-10vdc, you follow that?. its just a matter then of plugging in stepper drives & motors / power supplies to your interface card / breakout board. im doing one right now for a spindle, although on a lathe the principle is similar, down south.
    i'm not sure about the toolchanger, i imagine that would need control via modbus and serial port etc for the extra I/O's needed?. your limited with inputs from a parrallel port interface. do you need any inputs for a toolchanger?
    and maybe some custom macros to drive through modbus, somebody else might have done so?
    Apr 2008
    32
    update
    at the moment I am not sure about the spindle motor or anything else at the mo. I will take some pictures and post them tomorrow evening. I also have the parts manual so I can hopefully glean some more info from them. I responded to another post for someone else but they have not responded yet. If you do a search you will see my reply to the toolchanger sequence. Thanks for the quick response.
    Apr 2008
    32
    Photos
    Finally got a camera to take a couple of photos .I can't see the spindle motor at the mo because all the guarding is on . The motor on top though is the Z axis stepper .
    Hope the photos help .
    Attached Thumbnails Attached Thumbnails IMG_0112.jpg   IMG_0113.jpg   IMG_0111.jpg   IMG_0110.jpg
    Mar 2016
    325
    Re: Emco VMC100 rebuild
    Did You figure out the way of spindle speed control?
  1. Emco VMC100 Rebuild .. I need help..!
    By enok1969 in forum Norwegian
    Last Post: 09-17-2023, 10:41 PM
  2. EMCO VMC100 TM02, MSD to tape?
    By Viilari in forum EMCO Mills
    Last Post: 09-14-2020, 08:26 AM
  3. EMCO F1 CNC rebuild
    By ShowMeGuns in forum EMCO Mills
    Last Post: 01-05-2014, 05:23 PM
  4. Emco VMC100 retrofit
    By 30tooo in forum EMCO Mills
    Last Post: 09-16-2010, 01:09 PM
  5. Emco F1s VMC100.. Help ..
    By hjallis in forum European Club House
    Last Post: 02-15-2010, 12:44 PM
