585,712 active members*
4,045 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > how do I set my post processors
    4
    every time I start bobcad, I have to re-set my post processor to mach 3. Is there a way to change the default post processors for the mill and lathe?
    thanks,
    Alan
    Feb 2007
    77
    Look for a program in the BC directory called MEdit. This allows you to edit the machine file and customize it to your liking. Getting rid of the MORI machines if you don't have them is nice. Create a new profile for your machine using the mach3 post and put it at the top of the list. Then it will always be the default.
    Steve
    4
    Thanks Steve, That worked.
    Alan
    Jun 2008
    1838
    Re: how do I set my post processors
    No need to go editing your .xml file, simply go to "Cam Defaults > Current Settings > Select Posting > Select your Post in the Library > Select "Machine Parameters" and click the "Save as Default" button, now click the "OK" button, close BC and then when you re-open it your default PP will be the one you selected
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jun 2015
    6
    Rob
    Thanks that works also
    I hadn't tried it since it was listed as "Current Settings" thinking that was for the current session not for date forward default.
    Terry
  1. Post Processors
    By nivlek in forum BobCad-Cam
    Last Post: 06-06-2011, 10:39 AM
  2. post processors
    By Alisson Felipe in forum EdgeCam
    Last Post: 10-29-2010, 02:11 PM
  3. Post Processors
    By bigbadtom in forum Mastercam
    Last Post: 01-26-2010, 02:02 AM
  4. V20 post processors
    By doug6949 in forum BobCad-Cam
    Last Post: 02-22-2005, 02:49 PM
  5. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
