I need help to connect this type of spindle drive.
If you have connection or maintenance manual, please PM me.
The manual can be downloaded from meau.com.
Do you still need the manual?
[email protected]
Hi I'm new here, someone knows how to replace a FREQROL FR-SF or have a good one?
FR-SF Standard Specification REV-E
http://meau.com/functions/dms/getfil...00001817900000
FR-SF Maintenance Manual REV-D
http://meau.com/functions/dms/getfil...00001042900000
FR-SF Trouble Maintenance Manual REV-*
http://meau.com/functions/dms/getfil...00000459400000
Enjoy
If you are replacing the whole drive it should be easy enouh to match the wires numbers and their matches on the drive. however you need to check the dip switch settings from your old drive. if the new drives settings aren't correct you will encounter various errors and alarms. if you do not have the settings from your old drive you will need to reference the parameter book and compare with what options your machine has.
Any one has manual of FR-SFJ inveter (Not FR-SF). I have one nos of FR-SFJ-2-3.7k but don't have manual, so I could not make it run.
Thanks you very much.
Best regards.
There are two revisions of the maintenance manual for the FR-SFJ on the Mits site Mitsubishi Electric Automation Inc. - MEAU Home
