We have recently got a used Hi Cell 23 with a Seicos L multi controller but i am not certain if its a LI, LII, or LIII but i think it is the LIII (It says Seicos L Multi on the controller). It does have multi where we can program right on the controller. I have outputted G-Code from the controller to a computer using MasterCAM 9 with the communicate button through a RS232C cable with these settings:
Baud: 9600
Stop Bit: 2
Bit Length: 7
Parity Check: Odd
Com Port: 4
Handshaking: Software
EOL Delay: 0.0
We have set the communication in Master CAM to have the same baud rate, stop bit, bit length and parity check as it shows on the Seicos controller when we hit input/output. Now this is a used machine so we just left all the settings on the controller the same as we got it (which is the same as above) for both the input and output on the controller. The problem we are having is when we try to send the program back from the computer to the controller it gives us a "Parity Error" We have tried changing the parity to Odd, Even and None but it still does not work. Does the INPUT settings have to be different from the OUTPUT settings? The only other thing I could think of is when we output the program from the controller to the computer it puts a "square" or "box" right BEFORE the % sign at the start of the program which I believe is an unrecognized character that windows cannot read. It also puts another "square" or "box" at the end of the program AFTER the % sign. I have tried to delete these and send it back to the controller but it still does not work. Do I need a special character there that I do not know about before and after the % sign? I would also like to ask if anyone knows how to change the delay rate on the controller for when we want to input programs into it. Right now it only waits about 5 seconds before it times out and we must have 2 people (one at the computer and the other at the controller) for us to do it quick enough. Im guessing its a parameter setting?
Thank You in advance
