I have just purchased an XJ-25 mill from Amadeal in the UK. The tolerances on the spindle quill are not as they should be with lots of lateral movement. .2mm left and right, rigid front to back. No vertical movement. Can this be fixed by adjusting bearings or is it a fault with the machining of the quill/spindle? Has anyone done an upgrade on this machine?
