585,763 active members*
4,460 visitors online*
Results 1 to 6 of 6
    Apr 2007
    1955
    Electron Beam Writing Service
    Hi - this is on the extremely small end of cnc machining, but I will post it here in case anyone is interested.
    I work as a consultant for a company that sells Electron Beam Writers. (not electron beam welders) Their web site is here: http://www.crestec8.co.jp/englishF/
    You can think of electron beam writing as similar to laser marking, but instead of using a laser, it uses a very small electron beam - sort of like a CRT TV. It is substantially more expensive than laser marking as well.
    The size scale of writing is rather small. Typical feature sizes are 15 - 250nm, but features as large as 250 x 250 microns are viable. The largest item it can handle right now is 150mm x 150mm x 10mm thick. (some room to play there with the Z axis) but it must be flat.
    These systems usually write into resist (positive or negative) which is then developed, and pattern transferred with plasma etching.
    Typical applications are for research use in writing special semiconductor patterns, fresnel lenses, gratings and arrays, MEMS, miniature antenna structures, etc.
    If you follow the link, you will see that we have sold and installed one of these systems at UC Berkeley in CA, but there are systems in other countries as well. I am responsible for the system at UC Berkeley, and have access to writing time on the system.
    The E Beam writing work is performed by a PhD employee of Crestec (the manufacturer), and there is often a fairly high interaction level during the pattern setup process with the customer. Pricing, in case anyone is curious, is US$500 per hour - which is actually quite reasonable if you have ever tried to obtain this kind of service.
    Send me a PM if you are interested, or just reply to this thread and I will reach you via email.
    Harry
    Sep 2008
    Hey Sandra I am a student of mechatronics engineer .. I wish that I work with the Schematic of a generator of micro steps for a stepping motor.
    I appreciate your cooperation ...
    Apr 2007
    1955
    Hi Sandra, the application you are interested is a good one. This method has been used at UC Berkeley's sensor and actuator group (part of the mechanical engineering department) to make micro mechanical devices, including motors.
    Usually, the design of micro stepping motors like this are based on static electricity moving the rotor instead of magnetics. If you have a design, please draw it up in a cad file of some type and send it to me.
    I sent a pm to you with my email contact information. Please use that email for information.
    Thank you,
    Harry
    Sep 2008
    E-Beam writing
    I am doing some experiments with nanostructures and would like to speak to you regarding writing a nanowire pattern for me. I already have a pattern in GDS format.
    Please call me at (240)678-9475 so we can discuss this work.
    John Hagopian
    [email protected]
    Apr 2007
    1955
    Hi John - I sent an email to you. If it is ok, let's talk by phone on Thurs. Thanks
    Apr 2007
    1955
    Hi - just checking to see if anyone is interested in this service.
  1. FANUC-OMC / PMC ROM WRITING
    By iNUC in forum Fanuc
    Last Post: 06-07-2013, 05:45 PM
  2. writing G code
    By 300magnum in forum Australia, New Zealand Club House
    Last Post: 09-11-2008, 04:31 AM
  3. Writing words
    By JDARSNEK in forum G-Code Programing
    Last Post: 11-27-2006, 09:42 PM
  4. Anyone with experience in Electron Beam welders
    By DareBee in forum Welding Brazing Soldering Sealing
    Last Post: 02-01-2006, 03:04 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
