I just acquired a bunch of black plastic that looks and feels like some delrin I have. How can I tell for sure that it is indeed delrin?
John
John
Delrin feels like rock.
If it's Quadrant delrin, it'll have what look like oil stain marks on an unmachined surface - other types show a ridged surface.
And it's heavy. You can tell usually by the weight.
http://stores.ebay.ca/The-Great-Industrial-Garage-Sale_W0QQssPageNameZl2QQtZkm
Delrin is one of the most rigid plastics.
It will not soften as much with solvents like acetone or MEK that will soften PVC and ABS.
It machines a little bit like brass in the lathe when you have zero top rake and take a good cut.
If you burn a piece it creates a very acrid biting smell which is actually formaldehyde.
Thanks for the replies. I will give a piece the burn test, comparing it to some known delrin.
John
