Hello all,
I've got an Excel (Kiwa) 510 VMC with a double-arm ATC and am having problems where the tool change cycle. Will only work ONLY after a fresh M19 Spindle Orient command. Subsequent tool change requests, whether in G-code or manual, seem to hang up until the next M19. It's as if the control thinks the spindle has moved from its M19 Orientation. This just started one day after working normally for years. My first thought was that the brake on the double-arm gearmotor was the culprit. Turns out the motor and brake are working fine.
I'm not sure if I should be chasing down something with the Fanuc 0M control or the VMC hardware. To my knowledge, nothing has been changed in the control program or its parameters.
Any help would be greatly appreciated!.
MotoDan
