I have a Bridgeport 760 t16 vmc, I found out that the x axis encoder is bad. I am looking for a place that does repair work, or is able to replace the encoder .
thank you
thank you
I know of a VMC760.-16 I believe they had siemens motors. The encoder was a Heidenhain device. You should consult them about repair. Make sure the encoder cable is not the problem.
heidenhain is 1-847-490-1191
George
