585,971 active members*
4,059 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0iMC - Scales vs Encoders. Accuracy.
Results 1 to 8 of 8
    Feb 2008
    29
    Dear All!
    I've got the following situation. Milling machine has CNC Fanuc 0iMC and linear scales. I was measuring the machine accuracy using Renishaw Ballbar.
    So when the machine has only ENCODERS activated after some measurements and corrections of parameters 1851 and 1852 I had Backlash error about 5-7 micron, Reversal spike - about 10 and out of roundness about 12-15 micron.
    After LINEAR SCALES activation and setting 1851 and 1852 to zero Backlash error became even less but Reversal Spike and Out-Of-Roundess increased too much - about 20-25 micron.
    Renishaw help explaines that there is some slow reaction to reverse of motion direction.
    Do you have any ideas about this problem?
    Aug 2006
    98
    Leha_Bin,
    You only will take out the spikes change the gain´s of the motor´s.
    Daniel
    Nov 2006
    175
    Lexa,
    do not reset backlash to zero, leave 1 in 1851 for every axis, because if the machine has "backlash acceleration" set, it will not work. From my experience, using external feedback needs new adjustment procedure. "Servo guide" can help doing this, if you have it.
    Feb 2008
    29
    f-bu: Well, I think I don't have it. Could you advice where I can get it? And could you please describe "backlash acceleration"?
    Nov 2006
    175
    "servo guide" is Fanuc tool for adjusting servos. Chinese sites have it for downloading. For a pity it works with Fanuc supplied PCMCII ethernet card. Working trough embedded port or data server port return strange errors. Maybe it is version incompatibility, who knows. Someone told me that 16 bit card can be used instead, but I had no success with different ones.
    Backlash acceleration - see 2003.5, 2048, 2094, 2071 in servo parameters manual
    Typical setting is 1, 600, 600, 100, but depends on input increment and machine, so start from 50 for 2048/2094
    It is quite long to explain, I prefer to talk after you read it in the manual.
    PM для смены языка.
    Feb 2007
    Leha Blin,
    If you post an image of your Ballbar diagnostic report we may be able to provide some more insight on what exactly your machine is doing.
    Clive Warren
    Renishaw, Inc.
    Feb 2008
    29
    This is the result. If it's not enough to understand tell me what to add.
    Feb 2007
    Leha_Blin,
    Thanks for posting the ballbar plot, unfortunately without having access to the original .B5R file I cannot do any kind of in-depth analysis for you. However, something that you do need to keep in mind is that if your machine is using linear scales, it cannot have backlash (unless the scales themselves are loose!). What you could be seeing is the effect of the machine table yawing as it changes direction. To check this, re-test the machine with the ballbar in different locations on the machine table. If it is the effect of yaw, the apparent "backlash" will vary depending on where the ballbar is located.
    Clive
  1. Fanuc 0iMC PCMCIA CF Memorycard
    By anderin in forum Fanuc
    Last Post: 05-23-2022, 03:56 PM
  2. Glass scales as encoders
    By dcprecision in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2010, 06:51 PM
  3. encoders/scales on X2?
    By X2cnc in forum Benchtop Machines
    Last Post: 06-20-2008, 08:46 PM
  4. Sorce of used linear glass scales / encoders
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2007, 07:17 PM
  5. good source for cheap glass scales/linear encoders?
    By mbwittig in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2006, 05:58 AM
