585,748 active members*
3,523 visitors online*
Results 1 to 8 of 8
    Oct 2008
    7
    where can i get these fuses
    hi im new hear
    i have a problem with a peice of machinery that i need to get running
    im afraid i dont know the make of the machine but its a 4hp buffing machine
    today we wired it in and pressed start.complete silence
    after taking a few of the cover plates of my electriction friend said that the fuses were bust and poured a quantity of powder out of one of them.
    so i need new fuses
    but there unlike anything ive ever seen
    on the side they read
    the two conical ones as follows
    original diazed
    20a 500v
    kema keur
    70 cebec 55
    v d e
    a se v
    no.5SB27
    the straight one as follows
    AEI
    cable division
    type tdz
    i need to know where to buy these item new or if anyone might have some second hand ones
    please hepl
    plus ive put a pic of my colchester prior to its refurb.
    its now grey and going good
    Attached Thumbnails Attached Thumbnails 100_1590.jpg   100_1647.jpg   100_1648.jpg
    Feb 2007
    4553
    24220
    I doubt if the local electrical supplier would carry them, you might get an equivalent in Ferraz Shawmut or Gould Shawmut, but they most likely would have to be ordered in.
    They appear to be rectifier fuses, if so they would most definitely require ordering in, and expensive, on average $100 ~ $250.00 each.
    If on the off chance these are not rectifier fuses, it may be expedient and less expensive to fit in a current style fuse block with suitable fuses.
    I don't know why you would have rectifier fuses on a buffer, unless you have a solid state drive of some kind.
    Looking at the Littelfuse link, they just appear to be ordinary fast acting,
    Rather than fast sweep through Rectifier type.
    Al. .
    Albert E.
    Oct 2008
    7
    many thanks at least i know now what they called..ish
    i think it will only be one that i need as one is def shot however if they cheep i will replace them all
    im based in england btw
    24220
    Quote Originally Posted by mycoolbeard View Post
    Then Being European type fuses, they should hopefully be easier for you.
    Al.
    Albert E.
    Feb 2007
    4553
    Smile
    Check them out
    http://www.lawson-fuses.co.uk
    Jeff...
    Oct 2008
    7
    ive manuaged to find the two conical ones no proble and at a cost of 60pence each but am strugling to locate the straight one because of lack of part number
    many thanks for your help in this mater its made a other wise complicated process much easier
    Jul 2009
    Hi mycoolbeard.
    I have one AEI TDZ and have listed it on ebay.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
    hmhss is my user name if the link does not work.
    Regards mark
  1. Fuses on CNC setup
    By mtompson in forum CNC Machine Related Electronics
    Last Post: 09-10-2008, 03:51 AM
  2. Fuses & drivers
    Last Post: 11-20-2007, 09:08 AM
  3. Blown Fuses
    By sommerjd in forum CNC Machine Related Electronics
    Last Post: 10-01-2006, 10:02 AM
  4. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
  5. Confused about fuses.
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 09-25-2004, 05:54 AM
