Hi guys I am looking for information on a relatively simple machine which would best suite the basic function of drilling holes of varying widths (from 1mm to around 7mm) into 18mm thick wood (and maybe thin aluminium) panels as governed by a program such as VcarvePro. The panels diameters range from 22cm by 22cm up to about 1 meter by 1 meter.
This process is currently performed manually with a hand held drill and as there can be up to 100+ holes per panel and as the demand for the product has increased somewhat you can imagine this task can be quite tedious so any advice on which machine can produce this product automatically would be greatly appreciated.
Cheers
Mike
