585,978 active members*
4,401 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Export 3DSMAX files to ARTCAM PRO
    Jul 2008
    Exclamation Export 3DSMAX files to ARTCAM PRO
    Hi all,
    I wish to export 3DSMAX files to artcam pro software so as to be able to edit, define toolpath and send to Toolpath software suppoeted by AXYZ CNC Router.
    Can someon help?
    Nov 2008
    4
    What version of ArtCAM are you using 2008 seems to be able to do it from the project tree.
    Dec 2008
    Quote Originally Posted by fspl View Post
    Hi all,
    Can someon help?
    Hi, If you save your file in 3ds format you can simply import it in Artcam via File>Import...>3D Model.
    Hope this help
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. How do I export my artcam stuff to my cnc machine
    By thegimpster in forum ArtCam Pro
    Last Post: 08-05-2008, 10:09 AM
  3. SW Export to DXF
    By polymath in forum Solidworks
    Last Post: 06-04-2008, 02:20 AM
  4. dxf export
    By pminmo in forum CamBam
    Last Post: 10-07-2007, 10:58 AM
  5. scanner software to export dxf files
    By morsee in forum Mechanical Calculations/Engineering Design
    Last Post: 11-01-2005, 05:20 PM
