585,973 active members*
4,151 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > VERSION 22: 3d Toolpath problem
Results 1 to 8 of 8
    Oct 2008
    18
    When we generate the toolpath for a 3d shape e.g A 3d circular pocket with a radius in base, it is putting the code out in small line movements instead of using radius movements which is making the program way to long. is there a way of sorting this, thanks in advance.
    Jan 2007
    172
    No, this program breaks the circular segments down into lines, like most.
    Jun 2007
    65
    Onecnc XR3 will generate G02 and G03 in 3d tool paths as well as for the HS pocketing it will cut code size by 60 percent or more.
    John
    Jan 2006
    4396
    Quote Originally Posted by rftools View Post
    BobCAD V22 only uses line segments not arcs. It makes programs extremely long depending on how tight you make your tolerance settings.
    Mastercam, Surfcam, Pro/E, Visual Mill, and a few others actually create Arc Movements to reduce program size and increase accuracy.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2007
    6
    Will BobCAD V-22 run on a Win 64Bit sys??
    Feb 2007
    77
    Yes. There is a thread on BobCAD's forum on how to do it.
    Steve
    Jul 2007
    6
    Thanks but I cant seem to find it do you have a hyperlink??
    Feb 2007
    77
    Here you go... The issue was verify not working. But this is what you have to do on 64bit as well.
    http://www.bobcadsupport.com/forum/s...ead.php?t=3305
  1. toolpath problem
    By Nicovm in forum Jewelry Design Software
    Last Post: 09-02-2008, 07:39 PM
  2. Toolpath Transform problem...
    By kprice1658 in forum Mastercam
    Last Post: 03-13-2008, 07:07 PM
  3. Help toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-18-2008, 02:03 AM
  4. HELP Mastercam X2 toolpath problem
    Last Post: 01-16-2008, 07:59 AM
  5. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
