I have a K2 3925 machine. Ever since we got it we have had problems with the machine stopping in the middle of a program. It can be in any part of the program so I do not think its the G.code. its totally random.
I have tried to upgrade the machine little by little.
Actually we almost changed everything about the machine.
New better home swithces, better shielded cables to block out noise from the upgrade HSD high frequency spindle. New better Z-axis setup (came with the spindle) Stronger powersupply, PMDX breakoutboard...Latest addition are the US digital differential drivers that amps up the signal from the geccos. We read that if you have cables longer that 6 feet you need these... And we have longer cables.
After each upgrade we thought we had fixed the problem but nothing has helped this far
I just installed the drivers And it didnt get any better !! the machine still stops every now and then.
Before I go nuts, ( maybe its too late) Can someone please help???
Does anyone else of you have the same problem?
btw I have the servos not the steppermotors
/Berndt
