584,863 active members*
4,938 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > MIB press brake with Cybelec DNC 70 problem
    Oct 2008
    I recently purchased a second-hand MIB press brake with a Cybelec DNC 70 control system.
    It is not working properly. It doesn't work on semi auto mode even after feeding in the material data. On manual mode it comes down and goes up once, then you have to restart the machine. Sometimes, it totally refuses to work. The back gauge is not working and the x axis doesn't appear on the screen.
    Please advice what to do.
    pess break dnc70
    hey anoopka !
    just disable the x and r parameters(if existing).
    and go to the beam page and set the mex limit smaller then the existing.
    and then check the machine.also increase the sync valeu .
    or send me the screen shots of machine parameters then i can help you
    and we can tailor the parameters , step by step.
    hope it will help a bit.
    regards
    Jan 2016
    Re: pess break dnc70
    Quote Originally Posted by sohail0110 View Post
    hey anoopka !
    regards
    hello solail110 I have a hammerle with a cybelec 7000 and my press is not working the X and M axes . how I disablethese axes can you help me please
    thanks.
    atte
    lucioluciano
    Jul 2012
    28
    Re: press break dnc70 / gasparini POA 80
    Hello friends ,
    we buy in the past a Gasparini POA 80 but the operator of the machine is no more
    So nobody knows how to use the machine
    we don t have any instruction guide .
    Is there anybody that can help me ?
    maybe we can use a Video Call to simplfy the work
    Thank you
    My wattsaup is 0040745373715
  1. Barnes Press brake problem
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 09-29-2023, 09:25 PM
  2. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  3. Amada Press Brake Controller problem
    By jamesbond007 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:38 AM
  4. Selecting Press for home shop press brake
    By tikka308 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2009, 05:51 AM
  5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
