585,758 active members*
4,441 visitors online*
    Jan 2004
    85
    running direction problems
    hooked up the motors and they all ran except the motors wouldn't run at low feedrates they would just jimmy back and forth and when I would jog or run a short program the machine doesn't always run in the right direction, if I tell it to go in the - direction it might keep going in the plus direction but then it would go in the - direction there was no set pattern. using a laptop with +5v from the usb port and running cncpro. Any suggestions? Running Camtronics control stepper motors
    Greg
    6855
    You may not have a good ground. Change you're acceleration settings as well, the accleration may be to fast, it it's not set right the steppers will not run right .
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. mystifying 320 problems
    By senor J. in forum Gecko Drives
    Last Post: 01-20-2005, 02:40 AM
  3. Problems running G-code
    By milgo in forum Mach Software (ArtSoft software)
    Last Post: 10-31-2004, 05:27 PM
  4. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
  5. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
