585,926 active members*
3,640 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Each pass different than the previous
    Aug 2008
    Hey all, Got a simple question. Wen doing pocketing my pass rate is at .06 in and it takes 4 passes for a .25 in. The problem is that when all the passes are finished they dont line up giving the look of a stair case. What do I need to do to adjust this problem? Thanks for your input
    Apr 2006
    187
    Can you post the g-code??? Thinking we can solve your problem if you let us peek.
    Feb 2006
    210
    also check the rigidity of the spindle and bit
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Apr 2008
    82
    I had the same issue with my semi-new built machine I'm still trying to figure out. The 1st time I was missing steps, my motors weren't tuned yet. I had to lower the speed of my machine to correct that. Most likely that's your issue too. The 2nd time one of my worm-gear screw got loose (at the coupler holding the motor and screw together), so when it got tense enough near the end motors kept spinning but the screw didn't. This made my gantry move back to a certain distance then stop instead of continuing to move back to the accurate location.
    Nov 2005
    1468
    Climb Milling vs Conventional Milling?
    Your tool will deflect one way going from left to right (for example) and the other way comming back.
    Try unidirectional milling instead of bidirectional?
    I love deadlines- I like the whooshing sound they make as they fly by.
  1. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  2. g code for repeat the previous move
    By woffler in forum G-Code Programing
    Last Post: 03-27-2008, 04:07 AM
  3. Heidenhain pass
    By inioxos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 07:00 PM
  4. Can I run axes at different ipm on the same pass?
    By yorttroy in forum DIY CNC Router Table Machines
    Last Post: 01-04-2006, 07:34 PM
  5. the finishing pass
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2004, 12:58 AM
