585,760 active members*
4,037 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MC9 post -can't get "R"'s to post
Results 1 to 9 of 9
    Jun 2006
    17
    Angry MC9 post -can't get "R"'s to post
    I've been playing with this post for days and I cannot for the life of me, figure out where the problem is.I'm trying to get any helical motions(helix bore or threadmill toolpaths) to post arcs with an R-word instead of IJK's.
    The circular moves are posting with R's but not the helical motions. I'm trying to debug it and I keep getting taken back to pcirout1 and then follow that to parc and I can't spot the problem anywhere.Can someone take a look and tell me what I'm missing?
    Ace
    Attached Files Attached Files
    Sep 2004
    145
    look for a line in your post file like this:
    arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
    it's in a section labeled General Output Settings in the MPFANUC
    Mark
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Jun 2006
    17
    Sorry about that-I attached the wrong file- arcoutput was the 1st thing I checked
    Jul 2008
    139
    Cool
    R's posted fine for me, but you had debugging turned on. You might want to look at how the file was named, though. Here's what I got:
    Jun 2006
    17
    Thanks for the reply MCGuru,
    But the problem is with helical motions(XY and Z).As soon as a Z motion is introduced, the code starts posting with I's and J's.Try testing the post on a threadmilling or helix bore toolpath.If you have a copy of the SUBREP post you can see how I'd like it to post the code.
    ACE
    Nov 2007
    1702
    I had a similar problem in MCX. It's been awhile since I was in MC9 but in X, the problem was not in the post. MCX has a settings page where you set all of the output options for arc and circle handling. I would imagine that 9 must have a similar setting somewhere.
    Basically: the post only handles what gets passed to it. If MC is specifying IJK-type moves, that's what the post will generate.
    See the screen shots I posted near the end of this thread:
    http://cnczone.com/forums/showthread.php?p=440727
    Greg
    Jun 2006
    17
    The code posts correctly when using MPSUBREP post, so it must be in the post processor file
    Jul 2008
    139
    Is this better? Threadmill works - helix bore isn't cooperating yet..(It looks like force * is needed to push an R for helix bore rough pass) I commented out ijk selection in parc postblock. If you still need help with this post or it is creating a problem somewhere else, you can join in at emastercam forum. Those guys are really good with postprocessors.
    the site is: emastercam.com
    Jun 2006
    17
    Thanks Guru-see you there
  1. NEED MY POST TO SHOW UP ON"NEW POST" SITE
    By CNC_BOB in forum Mastercam
    Last Post: 09-30-2008, 02:06 PM
  2. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Fanuc
    Last Post: 08-29-2008, 06:58 PM
  3. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Post Processors for MC
    Last Post: 08-29-2008, 06:14 AM
