As I have no tool changer, frequently, I have to break up my cam files by tool type. On this current project, switching to a small bit for some fine detail, I inserted the bit too far into the spindle (ok ok so this was not the first time)... As soon as the router plunged on the first cut zap the over limit switch triggers, the router faults and resets to the default home forgetting my precisely eyeballed zeroing on the edge of the material....
So how do you all manage to reset home to something +- as few a thousandths as possbile?
BTW last time I tried to restart I was an impressive 1/8 inch off...
In the past couple of hours I thought of perhaps mounting a laser pointer on the gantry taping a paper with a dot at the home position...
What do you all do? Or does your machine accomodate maintaining the home even after a fault?
Dave
