Originally Posted by
archiebald
First off, I apologize if this question has been done to death.
It's my first post here, so a little background first. I am a time served mechanical maintenance fitter, but soon after my apprenticeship I got transferred to desk duties and never managed to get myself away from it. Now in my 40's I am living in Japan, I am into R/C Planes and Helicopters and I often need a lathe and or milling machine for making small parts so I am looking to buy a lathe and maybe a mill. My criteria are as follows;
1) The main problem is space, I live in a rented house in Japan and my hobby room is upstairs and not so big. Even if I had the space, I need to limit the weight to less than about 30~35kg per part to get it upstairs. I only intend to make small parts so lathe capacity is not really an issue.
2) Main work would be aluminium, carbon, brass, copper maybe even titanium. Very little steel or stainless (too heavy for flying models)
3) I would only need metric, no inches required even for thread cutting.
4) I have read quite a lot about the SIEG lathes in all their varieties and to be honest I am not so interested. I would prefer something of better quality without being too over the top on price.
5) The type of thing I am tending towards is the Proxxon PD230E, although ideally it is just a little too small. The Proxxon PD400 is a little too big. The Cowells 90ME looks lovely but really is out of my budget.
6) I have read enough to know that the combination lathe / mills are a compromise but for small lightweight work I think they might be enough. Again, because of space limitations I may choose to add a milling attachment later. Any comments?
Your buying advice please!!!
I think you are refering to the size of the work envelope when discussing the proxxons as being too big or small.
If the larger of the 2 proxxons is able to fit into your room go for it. You will find that no matter what you want to cut today, there is always a bigger piece on the horizon. If you are looking for quality in a small lathe, I don't think you will be happy with much else.
With the larger of the 2, you will be able to some small milling jobs on the lathe untill you buy a dedicated mill.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
