586,005 active members*
5,075 visitors online*
    Sep 2008
    4
    G08 on mori NV5000
    Hey guy's,
    Currently running a job in which we need to use the G08 look Ahead function on our Mori NV5000a1. We are running multiple parts at one time and are using sub routines. We can get G08 to work for the first part but when it jumps out of the sub, repositions to the next part then jumps back into the sub again, G08 will not reload. We did try multiple methodes of adding it in the program, examples below. It is needed as we are machining multiple contours and are running the speeds and feeds at 14000 RPM at 112 inches per minute on the 1/4" end mill the is maching the contour. Any advice would be great.
    Eamples
    G57X000Y000
    M98P0001
    G58X000Y000
    M98P0001
    G59X000Y000
    M98P0001
    G0Z2.
    G91G30Z0M19
    M1
    (SUB)O0001
    GO8P1
    G1Z-.01
    X
    Y
    X
    Y
    G08P0
    G0Z.1
    M99
    AND THIS WAY HAS BEEN TRYED AS WELL
    G57X000Y000
    G08P1
    M98P0001
    G57X000Y000
    G08P1
    M98P0001
    G57X000Y000
    G08P1
    M98P0001
    (SUB)O0001
    G1Z-
    X
    Y
    X
    Y
    G08P0
    G0Z.1
    M99
    AND THIS WAY
    G57X000Y000
    G08P1
    M98P0001
    G08P0
    G57X000Y000
    G08P1
    M98P0001
    G08P0
    G57X000Y000
    G08P1
    M98P0001
    G08P0
    (SUB)O0001
    G1Z-
    X
    Y
    X
    Y
    G0Z.1
    M99
    the subs are very long so I only inserted a few characters for an example.
    Nov 2005
    174
    Can you put the G08p1 at the begining of the sub then put the G08p0 before the M99.
  1. Mori SL-2
    By JMECKES in forum Mori Seiki lathes
    Last Post: 10-31-2008, 01:06 PM
  2. MORI
    By Mori in forum G-Code Programing
    Last Post: 07-07-2008, 06:16 PM
  3. Mori w/10T
    By grease in forum Fanuc
    Last Post: 10-26-2007, 11:10 PM
  4. Mori NV5000 lost X,Y,Z,W zero reference
    By teal854t in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2007, 02:34 PM
