As we all know, it's possible to do small milling jobs in a lathe with the use of a vertical slide.... but how about turning in a milling machine? By putting the tool in some sort of holder above the table the Z-axis would give you the equivalent of the saddle (or topslide) and either the X or the Y axis (depending on which way the tool is pointing) would give you the equivalent of the cross slide. Anyone done this? :idea:
