585,585 active members*
4,072 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Chip conveyor for LB15
Results 1 to 6 of 6
    Sep 2008
    111
    Does any one have a chip conveyor for a Okuma LB15? if so what brand/model? I am looking for 2. thank you
    brad
    Jan 2004
    33
    Hennig in Rockford IL made them for Okuma at one time.
    http://www.hennig-inc.com/chipconveyors.htm
    Oct 2008
    7
    re: chip conveyors for Okuma LB15
    Hi - what is the opening dimensions? width and length
    we may have some for you but we need the dimensions
    to see if we have the right ones!
    Donna
    [email protected]
    Oct 2008
    7
    chip conveyors
    Quote Originally Posted by cad01 View Post
    brad
    Donna
    [email protected]
    Sep 2009
    7
    I have 2 hennig conveyors. Okuma cadet and LB35. I am wondering who was the genius at hennig that decided to make the discharge end at the top smaller then the bottom and also have bolts sticking thru. If you are machine material that give you very stringy chips they get compressed at the top and hung up on the bolts that stick thru. It is apparent they were an engineer and not a machinst.
    Aug 2011
    2517
    We could start a new thread and fill up the whole internet with only info on machine design faults
    Engineer-designed products that have design issues are pretty common in most machines. Even the best machines have some design quirks.
    The best idea would be to have input from machinists with advanced knowledge on machine tool operation and advanced CNC programming. That is, people with engineering knowledge, hands-on knowledge and real world technical knowledge and the ability to adapt and learn on-the-fly. In reality that does not happen, possibly because those kinds of people are quite rare. I only know one such person
    On my twin turret Okuma the front of the rear turret (the side facing the spindle center) will hit the square chuck housing if using a small boring bar in a small bore. The square housing is way too big for what it does (which is basically to stop swarf getting into the bedways and headstock). They just didn't do enough research and development. It's all too common, unfortunately.
  1. Does anyone make a chip conveyor that works?
    By bob1371 in forum DNC Problems and Solutions
    Last Post: 04-03-2013, 04:53 PM
  2. turbo microfine conveyor troubles
    By jlockw in forum DNC Problems and Solutions
    Last Post: 02-09-2009, 04:46 AM
  3. 640t nexus chip conveyor
    By Lost-one in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-11-2008, 05:27 PM
  4. Where to get chip conveyor belt material?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2006, 10:37 PM
  5. turbo conveyor wiring
    By theguild in forum CNC Machine Related Electronics
    Last Post: 09-14-2006, 02:41 AM
