I need a program (fast) that will convert a .dxf file to a .dng file. Any ideas?
Brian
Not sure what a .dng file is. Do you mean .dwg?
No a .dng file. It is the file type that our EDM shop uses. They use Bobcad, I don't have Bobcad at home and I need to convert some shapes to send to them.
Brian
If that is bobcraps own extension, I would assume you would need to export the file from within bobcrap. I am not sure that there is a system out there that will do that. If its a dxf, dwg, iges, step, or something of that statue, it would be simple.
