585,894 active members*
5,029 visitors online*
    Mar 2004
    42
    axis goes plus or minus on it's own
    So check this out.
    One of my axis will "randomly" go + or - when I jog regardless of if I'm jogging in the + or - direction.
    For example, I'll briefly press the jog button for Z+ and the lead screw will spin in the +Z direction. I'll briefly press it again, and it will spin in the -Z direction. Press the Z+ button again and who knows....
    I have a homebrew 3 axis mill with Xylotex driver and Mach 3 software on a PC. This is only a recent problem, and not a problem with the motor (i've switched cables to other motors) and not a problem with a specific axis on the driver board (i've switched pin connections in the mach 3 software).
    By process of elimination, that leads me to believe it's the computer.?. Has anybody seen this before?
    Any help is GREATLY appreciated. THANKS!
    greg
    Jan 2007
    599
    Sounds like loose wiring between you stepper drives and breakout board.
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  3. Starting at MINUS Z depth problem
    By SScnc in forum Vectric
    Last Post: 09-21-2008, 02:58 AM
  4. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
