585,728 active members*
4,696 visitors online*
Thread: jet ranger
    Oct 2007
    jet ranger
    hi, I am looking to make a jet ranger fusalage for mu trex 500 doese anyone no where i can get a 3d drawing of a jet ranger so i can cut this out & fiberglass over this
    Jan 2007
    5
    jet ranger
    I am having the same dream for my Hirobo Shuttle. I found attached Jet Ranger 3D model from http://cben.net/.
    I converted it to dxf, removed blades and landing skids and generated toolpaths for home made CNC router.
    I haven't made the Shuttle size body yet, but I tried to make raw 10 cm long model out of foam to test the whole process.
    Attached Files Attached Files
    Oct 2012
    I have an Rc-Jet named as "4 Channel RC Jet F-22 Camo "Raptor" - RTF". The F-22 is acclaimed for its many resources, as the world's most effective aircraft in upper air attack. He drives an electric turbine for standard 70 mm along with a powerful 2836 brushless motor and speed control (ESC) 45A 5A UBEC. The battery has been upgraded to a Li-Po 14.8V, 2200mAh which gives more power and speed. It flies very fast and has tremendous wing area.
    Flying Rc-Jet is a Real Fun..Nitrotek
