585,599 active members*
3,734 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Machining Tantalum-Tungsten
    Sep 2008
    199
    Hey,
    I have a .25" (Approx) piece of Tantalum (with 2.5% Arprox Tungsten). I need to face this down to 0.160. I am going to Use a 1" indexible end mill with Carbide inserts. And Recommendation on feeds and speeds and depth of cut? There's no info in the Machinery's handbook.
    -JWB
    --We Ain't Building Pianos (TCNJ Baja 2008)
    Nov 2007
    479
    found this, could use this as a starting point
    http://www.hcstarck.com/index.php?page_id=354
    Sep 2008
    199
    Hey,
    Thanks a lot I'll defaintely take that info into consideration. Odd though because Mastercam actually has Tantalum in it's materials library and it gives a SFM of 140, which is what I'm using right now along with a Feed per tooth or 0.0001 because this is what Mastercam gave me for another job. I'm also using a depth of .005 just to get a feel. Unfortunately I actually don't have any HSS end mills to use. I'll try these values out afterwards though and probably change my inserts. This material takes so long to machine.
    -JWB
    May 2008
    84
    tantalum
    Have some questions on your tantalum experience. Sent a PM, but your PM box is full... Please empty..
    ca
    Aug 2010
    What's the material condition? As long as it's not annealed, shouldn't be much of a problem. Use speed/feed data for Titanium, from whichever manufacturer you use for your cutter. Very highly positive cutting geometries seem to work best, moderate feed, lower speeds. 125-175 SFM, .004-.006 inch/tooth, keep the axial depths under .100, radial .2-.3D (peripheral milling) at the higher SFM range, .65-.7D radial (rough milling) at the lower range.
    The Manufacturing Reliquary
    http://cmailco.wordpress.com/
  1. tungsten feeds and speeds question!?!
    By dcrblazer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2014, 01:53 AM
  2. Threading 99.9% Tungsten Rod?!?!?!
    By stuby in forum MetalWork Discussion
    Last Post: 08-01-2008, 04:15 AM
  3. Tungsten Alloy???
    By stebanski in forum MetalWork Discussion
    Last Post: 10-01-2007, 10:17 PM
  4. Tungsten-Copper Elkonite
    By pqminc in forum Composites, Exotic Metals etc
    Last Post: 08-14-2007, 12:38 AM
  5. Chemical Tungsten sharpening
    By zcases in forum Welding Brazing Soldering Sealing
    Last Post: 12-12-2006, 12:12 AM
