585,922 active members*
3,863 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Need method to apply thread Lubricant (high volume assembly)
Results 1 to 6 of 6
    Apr 2005
    81
    I am looking for a good solution to apply thread lubricant to various hardware quickly and cleanly. Current process takes to long and often results in lubricant on hands which mark final product which can't be easily cleaned. I"m thinking almost a lubricant well to dip hardware then something to remove excess. Anything on the market like this, or am I just going to have to end up making my own? current process consists of laying out hardware, taking lube bottle with small tip to apply to individual bolts then rolling to ensure good 360 degree coverage, messy and time consuming. Lubricant viscosity can be varied based on application method needs.
    Any suggestions welcome.
    Dec 2006
    325
    Have you thought of using feltpads or cotton swabs that would bring the lubricant to the bolt thread?
    Best regards
    Bruno
    Oct 2006
    44
    A paintbrush
    Jan 2008
    24
    Try this
    What about an airbrush setup. Cheap to purchase, and accurate. This would probably work if your lubricant is thin enough.
    Chris
    Dec 2008
    3109
    What about a syringe ?
    with a foam pad glued around the stem , similar to a liquid boot polish applicator
    Aug 2008
    573
  1. High Power UHU Thread (HP.UHU)
    By contactirfu in forum UHU Servo Controllers
    Last Post: 07-28-2022, 08:26 PM
  2. Method to internal/external thread ?
    By PeteGallo in forum Uncategorised CAM Discussion
    Last Post: 04-03-2007, 03:50 PM
  3. What's the best method to turn a thread and a 3/32" bore concentric?
    By Darc in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2006, 12:34 PM
  4. High pressure low volume water pump
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 06-25-2005, 08:36 AM
  5. High Volume Vacuum Tables
    By azsigns in forum DIY CNC Router Table Machines
    Last Post: 02-27-2004, 09:04 PM
