585,894 active members*
3,881 visitors online*
Results 1 to 14 of 14
    Nov 2007
    2466
    vacuum tables and pumps
    lets put it here
    letter from bill on the subject,
    There is much confusion about what kind of vacuum pumps are needed for different applications regarding hold-down on CNC Routers. Many of us think that more horsepower automatically results in better hold-down and opt for more HP and of course more electric bills. I will try to give an unbiased view on how it works and what works best from a (kuntryboys) way of saying it. I have used everything from reverse blowers from Grainger that will work on 220 single phase to 25 HP regenerative blowers to Positive displacement pumps such as Becker, Busch, or others. I have built CNC routers for 13 years and just lately feel like I understand it enough to really help someone else understand it. For most people including myself, we may think that a pump holds down parts because it "sucks the part down with air". When we understand what really holds the part it will help us understand more about holding down parts. Piab is a company that makes small vacuum cups, small pumps, etc. Several years ago I read a book they had and it explains very well how it works and it was very interesting. Basically without getting too deep into science this is it:
    On what is called a standard day which is 59 degrees F at sea level air weighs about 15 lbs per square inch. Think of it as a column of air 1 inch square that goes all the way toward outer space until there is no air molecules. If you live in the mountains say at 2000 ft in elevation then your column of air is going to weigh less because there is not as much of it to weigh. If any of you are airplane pilots then you already know that the hotter the temperature the farther apart the air molecules are and the longer it takes to get off the ground and the slower you will fly. The same is true with vacuum. It will not hold down with as much force the hotter it is and the higher in elevation you are. But remember this column of air is fluid so it will try to replace any vacuumed areas. THIS IS VERY IMPORTANT. Air only weighs 15 lbs per square inch maximum. It cannot be made to weigh more with any size vacuum pump because the most you can vacuum out of anything is whats there. (15 LBS. MAX) if you have a 10" square you are trying to hold down the maximum you can hold down with is (10" x 10"=100 square inches) = 1500 lbs of force. This is only with a pump that will pull 28-29 inches of vacuum. This can be accomplished with a positive displacement pump such as Busch, Becker, or others that can pull this kind of vacuum. Regenerative blowers on the other hand cannot pull this kind of vacuum but are more on the order of 10-12 inches which would make its hold down force per square inch be more around 6 or 7 lbs per inch. If you were holding the same 10 inch sq piece of material it would be held down with more like 60 or 70 lbs.
    Positive displacement pumps would probably be the ultimate but we have to remember that they do not put out the same volume as a regen blower. They put out much less per given HP because they are doing more work so you must find a balance. They also require more HP to get the job done. So if you use residential electricity you may find that you want to go with a 5-7.5 HP positive displacement pump such as Busch, Becker, etc and make sure you don't have leakages etc. I will mention some tips there later. If these pumps are too high new there are several companies that sell rebuilt ones with a guarantee. If you have plenty of electricity you may want a high volume regen blower such as Fuji, FPZ, etc of 20 or 25HP and when you have that kind of volume you don't have to be as bothered by leakage. On a 4 x 8 table I feel that 10 HP regen and below is a little bit marginal. Of course there are huge vacuums that will pull huge volume and high vacuum but most of us are trying to do CNC on a budget and could live off some peoples electric bills. Positive displacement pumps generally cost nearly 2-3 times the price of a regen blower.
    I have a customer who has 2 of our machines. I was surprised to learn that he is running both tables with 7 1/2 HP rebuilt Busch pump that pulls 28-29 inches and has decent volume. He paid about 3300.00 for the pump. He is careful with his leakage. Heres how he does it:
    Our low-cost vac tables are MDF 1 1/2" thick with a grid sytem cut into the table with 4 zones on a 4 x 8. Each zone is 24" x 49" with a 2" PVC pipe running to each zone that has a PVC cut off/on for each zone. He mills a sheet of 3/4 LDF or MDF on one side. He then adhere this to his grid table being careful to only put the wood glue on the grid itself so as to not seal up the bottom of the sacrifice board. This keeps the sacrifice board from becoming sealed. Then he mills the top of the sacrifice board. He also then seals up the edge of the sacrifice board to not let air escape through the edges. When you cut your parts be careful to set your z so that it doesn't go unnecisarily deep into the sacrifice board. When the sacrifice board gets uneven and is affecting the vacuum you can then remill the board just enough to clean it up. When you get down to the grid again simply do the same with another board and start over. This works very well. (Thanks to Greg Westberry for the enlightenment on how he does his vacuum system and some help on the above info as well)
    I have also found that if you have limited electricity available such as only 220 single phase and don't want a phase converted setup that a Dayton 10 HP blower working in reverse works fairly well because it has such a huge volume but uses a lot of electricity to start and you have to build a different vacuum box to handle the volume.
    Hope this helps a little in making your decisions. I will try later to give some tips on how to cut parts with low volume or no vacuum at all.
    Bill Glenn
    Camaster CNC
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Aug 2007
    422
    intresting, subscribed
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Nov 2007
    2466
    that was a cool site!!
    do the planes take off from a "tail start" ?
    jim
    Jul 2005
    12177
    That is a really good explanation.
    Humorously a couple of years back I suggested increasing the holding power of vacuum by pressurizing the room everything was installed in but still having the vacuum pump exhaust to the outside. If your room was at 15psi then you get two atmospheres of hold down, 300lbs for your ten inches square. Not exactly feasible.
    Here is a serious suggestion which I did make once and cannot recall getting any feedback, but I think it could be a successful high volume fairly high vacuum source. Find an old V6 or V8 engine that has separate intake manifolds for each cylinder bank, or has twin carbs one for each bank. Remove one carb and hook your vacuum line here and run the engine on the other carb. This setup should pull 24 or more inches running at a few thousand rpm and has the advantage that it can be boosted up to get a high volume for the initial pull down and then throttled back when everything has tightened up.
    Nov 2007
    2466
    we racing!!! or cutting cabinets, i'd like to see that!!
    jim
    10x10x15 = 1500 lbs, not 150.
    Nov 2007
    2466
    whoops!
    Jul 2005
    12177
    Clearly I was asleep also.
    Nov 2007
    2466
    Aug 2013
    7
    I have a 12 x 5 foot wood torsion table home built that I cut an area 4x8 into a checker board squares .25 wide and .25 deep. I broke it up into six equal sections with two each 2" vacuum holes. For vacuum pumps I used two 6hp Sears shop vacs cost $79.00 each. I use .75 mdf waste board that has been surfaced on both sides .06. Works great in fact I can't believe how well it works. So you can do it for little money.
    Nov 2007
    2466
    Are you using it for a Vac table for Veneer or a CNC hold down?
    Aug 2013
    7
    Hi James
    I am using it for a CNC machine but I think it would work for either. If you go to this link you can view my photos of my CNC router build pretty much start to finish.
    https://plus.google.com/photos/10804...401?banner=pwa
    There are a couple of videos of a test table I built before I cut into my machine as I wanted to see if it worked well enough. This table was one sixth the size of the surface i cut into on my table bed. At that time I didn't know that you were suppose to surface the MDF before you used it but it still worked great. I created a manifold so I could isolate portions of the vac area into six rectangles but have found that it wasn't really all that important as I can hardly tell a difference when using a small area over leaving it all open when I am only cutting a small piece.
    I started this project two years ago not knowing very much at all so it has been a real learning experience for me. I though all you needed was a CAD program. The wiring really had me going for a while and over time I found that aluminum rails had some real draw backs and cheap limit switches sucked as well. I found many ways not to do things over time but have now with the Vac table really have things going my way. Jerry
    Mar 2011
    Re: vacuum tables and pumps
    Quote Originally Posted by akbound View Post
    Hi James
    Hi Jerry
    Your CNC build looks impressive. Well done. I'm especially interested in the vacuum table you built. Two years on is it still going strong? I'm curious as my vacuum table does not seem to have the same ability to hold down parts like yours.
    With limited air going through the Sears Shop Vacs how have the motors stood up to this heavy treatment (i.e. with limited airflow to cool their motors)? Cheers, David.
    Aug 2013
    7
    Hi David
    The Vac table works as good as ever. I have found that if I have a piece of material that will not lay flat enough on the table for a seal around the edge. I use some masking tape on the outside edge and that will pull it down flush to the table. Also if it is a small piece of wood I am cutting I put the tape around for a better seal and that usually does the trick. I do surface both sides of my MDF before I use it. The MDF goes through a roller and seals the surface so I surface both sides about .06 before I use it. That may help you some.
    Best of luck Jerry
    [email protected]
  1. Replies: 0
    Last Post: 10-25-2010, 07:46 AM
  2. Vacuum pumps off ebay
    By JanHenning in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-19-2009, 09:38 AM
  3. Found surplus pumps for vacuum forming
    By kayaker43 in forum Vacuum forming, Thermoforming etc
    Last Post: 06-13-2007, 05:53 PM
