Is it possible to change a 6 wire stepper to an 8? Is the center lead tapped into the coil or are there really 2 coils in series?
The centre wire is common to both coils.
If you open the back of the motor, you will see where the common wire can be separated and brought out to make an 8 wire motor.
See thread
http://www.cnczone.com/forums/showthread.php?t=13793
Schematics look like series. I have a 4 terminal output from my controller(+A,-A,+B,-B). So my manual said to discard center connection of motor and treat two sets of coils in series. It says if I do this I will have to half the current though.
I have 125oz/in 2.0A per phase motors that I’m running at 1A this way and they have virtually no torque. Is there anything I can do to over-clock them for the time being. I plan on getting bigger motors in the future.
