Does any have a simple setup sheet or know how to modify the default MILL.SET, Nothing fancy I only need the tool num, name, lenght,dia. etc. Just enought info to load the tool changer. All the other BS on the sheet makes it hard to read
right mouse click in the operations manager and select doc file, this will give you less info. For a long term solution go to emastercam.com and click on this link http://www.emastercam.com/ubb/ultima...c;f=1;t=031482 if you are not registered, you will need to do so. You can download the free setup sheet for Mastercam X3, previous versions are also available, search for X+ and your mastercam version
Or just use my link and download it from my server.
http://www.mastercam-cadcam.com/setupx+_x3.zip
Cadcam
nice, you don't even need to speak GermanOr just use my link and download it from my server.
did it come in Germain I have the english DLL file to make it inglish. will post it later.
Cadcam
Thank you very much, I will try it out monday.
I personally don't care for the X+ or In-house Solutions setup sheets.
Here is my modified mill.set if anybody is interested .
The X+ setup sheet is not a .set. When unzipped it is an .exe that has to be installed for use.
It then is run as a c-hook.
This forum only allows a few specific file extensions so it will be impossible for somebody to post a .set or a .exe file for you unless they temporarily "rename" it using a different file extension.
If you PM me your e-mail address I can get it to you unzipped.
Thank you for the help, that one is alot better.
