586,000 active members*
4,928 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Mitsubishi 90c wire edm - where do these wires go ?
    Nov 2005
    4
    had the main switching unit removed for repairs.
    There was a transformer connected to it that I think was an upgrade.
    when it was returned, the transformer was removed and the guy that worked on it doesn't remember witch screw terminals it was hooked to.
    the transformer sits in the space where a second switching unit would sit.
    because it is an economy model, it only has one unit.
    If you have this machine with this transformer added, could you look in the back of the controller and tell me witch terminals the transformer is hooked to ?
    Jan 2006
    2985
    First: Beat the guy who took it apart without labeling.
    Second: Pictures are often helpful in resolving problems such as yours.
    Good Luck
    Matt
  1. Mitsubishi Wire EDM
    By Roswell28 in forum EDM Discussion General Topics
    Last Post: 01-08-2022, 02:47 PM
  2. Mitsubishi Wire EDM
    By Roswell28 in forum Esprit
    Last Post: 12-04-2008, 05:14 PM
  3. Mitsubishi FX1 Wire
    By one4design in forum EDM Discussion General Topics
    Last Post: 10-05-2008, 07:37 PM
  4. Mitsubishi EDM/Wire Cut Systems
    By flomatic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-06-2007, 04:56 AM
  5. Can you wire a Vexta Stepper to run Bipolor that has 6 wires
    By journeyonline in forum Gecko Drives
    Last Post: 05-17-2007, 04:24 PM
