586,024 active members*
4,367 visitors online*
Thread: DC Amplifier
Results 1 to 11 of 11
    Nov 2005
    73
    DC Amplifier
    I have a general question about amplifiers . Is it possible to turn 12 volts DC into a greater voltage ( like 48 or 96 or 108 volts)and where would I find such an amplifier or do I need to have one created for me special pupose ?
    Any help would be greatly appreciated .
    24221
    Depends if you want this variable or not, there are many power inverters used for 12v to 120vac on the market, you would need to put a bridge and capacitors on the output, but these are non-variable.
    Also your current capability will go down in direct relation to voltage increase.
    Al.
    Albert E.
    Nov 2005
    73
    So I could use a power inverter and change the output to DC by doing the same as a car alternator ? And what do you mean current going down is this what they mean when they measure amps ?
    24221
    Quote Originally Posted by Derek.C View Post
    The same principle, yes.
    The power consumed by the 12v input, will be roughly the same as the power output rating, and as power is a product of amps x voltage, if you raise one, the other has to go down.
    Al.
    Albert E.
    Nov 2005
    73
    Ok AL I am really new to the electrical side of things . So to simplify for me
    you are saying if I have 12 volts and 60 amps and I increase the voltage the ampeerage that I can draw upon will go down .
    Nov 2005
    73
    Quick question AL explain power . I know what amps are and I know what voltage is .
    But the translation to power is ? Horse power . By the way thank you for the reply I do appreciate the help understanding what is to me a mystery .
    Nov 2007
    1702
    Power is Watts. 746 watts = 1 hp. Watts is basically fixed. If volts go up, amps go down.
    1.2 volts x 10 amps = 12 watts
    12 volts x 1 amp = 12 watts
    120 volts x 0.1 amp = 12 watts
    There are conversion losses in any voltage transformation so you can't count on that being your output but in a 100% efficient world, that's how they equate.
    Greg
    Nov 2005
    73
    Thank You
    Mar 2007
    215
    I think what your looking for is a dc to dc converter....
    Tell us a bit about what it will be used for and we can give you a better answer...
    Mar 2007
    215
    Allrighty... According to the PM you sent me, you want to convert 120VAC to 120VDC...
    Rectified 120VAC will not give you 120VDC, it will give you 120VAC * 1.414 = 170VDC...
    Rectified AC without the use of an isolation transformer is incredibly dangerous... It has the potential to kill...
    I would suggest a transformer to step down the 120 AC to roughly 85 volts AC ...
    And then rectify and smooth... The resulting no load dc voltage would be roughly 120VDC...
    You may want to go a little higher than 85VAC to make up for losses, etc...
    Calculating a safe VA rating for the transformer requires knowing how much power is required....
    There are lots of examples on Google... Here's a few http://www.juliantrubin.com/fairproj...ycircuits.html
    You may want to avoid the DIY approach and just get a SMPS... It would be lighter and smaller than a traditional design... There are quite a few high voltage models designed for car amplifiers...
    Nov 2005
    73
    Yes Krazatchu I would love to avoid the DIY . That is why I am here to pick the brians of the more knowledgeable .
    So in converting the AC to DC will I lose amperage or will I gain like on the voltage side . Also what does SMPS mean .
    I would like to keep the 20 - 30 amps that I will be inputing as well but keep the converter as small as possible .
  1. FANUC 11M Amplifier bad, need help!
    By posedi in forum Fanuc
    Last Post: 11-11-2009, 04:50 AM
  2. CMC/EG&G brushless amplifier help
    By knightlord in forum Servo Motors / Drives
    Last Post: 07-18-2006, 04:45 AM
  3. FANUC 11M Amplifier bad, need help!
    By posedi in forum DNC Problems and Solutions
    Last Post: 04-19-2006, 04:10 PM
  4. Help with CMC amplifier ACS5013-0-000
    By cnogueiraneto in forum Servo Motors / Drives
    Last Post: 03-26-2006, 02:14 PM
  5. switching amplifier
    By teilhardo in forum CNC Machine Related Electronics
    Last Post: 04-22-2004, 02:10 AM
