Anyone using this add on? Can you add this to a home build machine?
Mick
Mick
If you are referring to our Plate marking attachment, then yes I believe it could be mounted to another system. It comes with a standard 4 hole offset mount that you could bolt to your gantry. All you need to supply it is Air and a CNC controlled switched 120 volt AC power supply.
-Mike
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Mike,
How much is the kit and what software is needed?
Thanks!
Mick
