also:
Under the main menu, go across to "Operator" then "G code Var Monitor"
this will bring up a dialog box, you put in the stored Parameter number in the parameter box, and the value of that paramter will show in the value box.
so, if lets say you have your example: (#1=1.500 for example)
in the dialog you type in "1" in the parameter box, and hit the update button, then "1.5" will appear in the value box, (obviously only if you set it by G code, MDI or VB script.
If you do a custom macro you can get and set Parameter vars like this:
GetVar(var#) 'parameter number in the parenthesis
SetVar( var#, value (as double))
scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
