585,712 active members*
3,979 visitors online*
Results 1 to 7 of 7
    Feb 2007
    29
    Hypertherm HD3070 question?
    Hi I'm looking to buy a Hypertherm HD3070 used to work with my home built plasma table. I have already a fabrication shop and i looking to make more parts (welded assembly and construction miscellanous) that I typically send to a laser shop. I'm looking to get better turn around time for small batch run. I have a couple of questions about it.
    Am I able to use Bob Campbell Thc with this system or i need a commercial one ?
    My other question is about the cost of consumable versus a basic Air plasma, is it more costly to initialy buy and then you save over the long run or you spend only for greater cut quality??
    What about all the gases that you need, how much can it cost to get me started ??
    I heard that you can also change the torch for a newer one is it worth it and how much does it cost?
    Thanks a lot for your help.
    Francis
    Jan 2008
    2247
    The 3070 is no longer manufactured....but it is still a very strong high definition class plasma system. There is a torch upgrade available from Hypertherm that allows you to use the new HPR130/260 torch on that machine....better cut quality and longer consumable life are the result.
    That system is a high frequency start torch.....so be sure you follow all of the best practices available for hardening your cnc control and electronics ffrom this source of electrical noise.
    The system has good consumable life as is...assuming it is operated as designed (follow all the procedures in the Hypertherm manual in regards to gas pressures and flows, cut speeds, arc voltage and pierce height). With the HPR torch it will perform even better.
    If you are only cutting carbon steel....you will need oxygen and nitrogen for this system when using the original torch....if you are using the new HPR torch.....you will use oxygen as the plasma gas and clean/dry compressed air as the shield gas.
    You can download a manual from the www.hypertherm.com website if you need one....be sure you specify whether you have an "auto gas" or "manual gas" system......the auto gas has all digital gas flow controls....while the manual gas version has flowmeters and gauges.
    Jim colt
    Feb 2007
    29
    thanks a lot Jim,
    I will contact my hypertherm salesman for further pricing.
    Mar 2014
    7
    Re: Hypertherm HD3070 question?
    Quote Originally Posted by jimcolt View Post
    Jim colt
    Hi all, (Jim Colt in particularly :-) )
    We have recently bought a used plasma, 6x2m table with HD3070 - manual gas and upgraded torch. We are now installing the machine.
    At this point I need to find out:
    1. what is the consumption of O2 and N2? Meaning of flow rate (ipm/scfh) and test flowrates from manual gas console cut chart for upgraded torch?
    2. Is it possible to use air/air or or O2/air, and what would be the parameters for mild steel, 70A and 100A?
    We would mostly cut mild steel S235, S275 and S355; 5mm thick and 10mm thick.
    We have an industrial compressor 45kW with suitable dryer. Plenty of air, 5400m2/h, 10bar.
    From manual, worst case conditions, delivery of O2 should be 77,8 scfh with 120psi. I estimated that bottle of 8,4kg under 150bar would last 4min of arc time under this conditions. Is it correct? I expect that consumption in operation is 50% of worst case, giving me 8min, which is still rather unusable...
    So, for test during installation and maybe even later for production, it would be most convenient to use air for shield, and maybe even for plasma or O2 for plasma and air for shield. From Jim's quote this sounds viable. Is it?
    In manuals for HD3070, even for upgraded torch, and Operating Instructions from plasma cutter manufacturer, there are no parameters for air/air for mild steel. How do I choose suitable Amps, travel speed, Torch to work distance...
    Jan 2008
    2247
    1. what is the consumption of O2 and N2? Meaning of flow rate (ipm/scfh) and test flowrates from manual gas console cut chart for upgraded torch? The gas flow specs are in the upper right corner of the cut charts for the upgrade torch.
    2. Is it possible to use air/air or or O2/air, and what would be the parameters for mild steel, 70A and 100A?The only recommendations are to use the gasses suggested in the cut charts. The use of air as either plasma or shield gas will affect cut quality and consumable life. Since this is an older product and other gas testing has not been done.....I cannot speculate on the exact outcome. It is possible that air may work satisfactorily as a shield gas, assuming it was clean and dry and at the same inlet pressure as the suggestion for nitrogen. I definitely do not recommend air as the plasma gas...this system was designed for cutting steel with oxygen.
    Quote Originally Posted by Hrvoj View Post
    From manual, worst case conditions, delivery of O2 should be 77,8 scfh with 120psi. I estimated that bottle of 8,4kg under 150bar would last 4min of arc time under this conditions. Is it correct? I expect that consumption in operation is 50% of worst case, giving me 8min, which is still rather unusable... A standard high pressure cylinder of Oxygen holds about 240 cubic feet. When I do the math I would expect over 200 minutes of arc on time. This system, when used as suggested will cut steel with far better quality and at a lower operating cost as compared to an air plasma system. So, for test during installation and maybe even later for production, it would be most convenient to use air for shield, and maybe even for plasma or O2 for plasma and air for shield. From Jim's quote this sounds viable. Is it?
    Mar 2014
    7
    Thank you, Jim,
    I can't get to 200min, but 43,3min. Usable, compared to what I thought I'd get, 4min :-)
    I am relaying on your experience that I should get 200min
    To check the math,
    supplier specifies content of the bottle : O2 (8,4 kg, 150 bar)
    and conversion rate: 1 kg = 0,763 m3; 15°C i 98kPa (735,5mm Hg)
    8,4kg x 0,763m3 x 1bar = A x 150bar => bottle content (A) = 6,4 / 150 = 0,0427m3 under 150bar
    A x 150 = B x 8,3bar (120psi) => (B) bottle content = 0,0427 x 150 / 8,3 = 0,772m3 under 8,3bar
    cutflow for plasma O2, 100A, mild steel is 64scfh
    test cutflow flowrates for plasma O2 is 59%
    Consumption flow, arc on (O2 plasma, mild steel, A100) = 59% of 64 scfh = 37,76scfh = 0,01782m2/min
    time = volume / flow = 0,772 m3 / 0,01782 m3/min = 43,3 min
    Is this OK?
    Best Regards
    Nov 2019
    8
    Hello, let me know if you need spare parts or a replacement machine.
    https://supplychain.requis.com/procu..._records/68089
  1. hypertherm hd3070 problems
    By glennoli in forum Waterjet General Topics
    Last Post: 11-26-2019, 11:09 PM
  2. Farley / Hypertherm HD3070- Laserlabs Rapier Help
    By 88incher in forum Waterjet General Topics
  3. Hypertherm question
    By martinthelion in forum Hypertherm Plasma
    Last Post: 04-19-2011, 04:15 PM
  4. KCR-HD3070 Project: Retrofit Komatsu Rasor KCR-0951 w/ Hypertherm HD3070/Sensor PHC
    By racesol in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-02-2011, 08:31 PM
  5. JimColt... Question About Hypertherm
    By xendau in forum Hypertherm Plasma
    Last Post: 02-17-2011, 06:22 PM
