585,977 active members*
4,138 visitors online*
Results 1 to 3 of 3
    Aug 2004
    48
    Thumbs up A Drill Bit Reducer
    Hi guys, I have a tiny problem. I purchased 2 reamers one, 7/8" and the other 3/4". I have a Microlux 7x14 and a MT-2 tailstock. I have a 1/2" chuck which I just purchased and slghtly used. The problem is the reamers are not reduced to 1/2" like my drill bits are and my only choice is to buy a 3/4" Chuck and arbor which is another $100. Is there a way besided machining my own adapter that I can buy this from a site. It must exist.
    .:: gdl357 ::.
    Aug 2003
    812
    Can you chuck them up and turn them down to 1/2"? That would be more accurate than an adaptor I would think.
    Aug 2004
    48
    Ordered my 3/4" Drill Chuck. That should solve the problem. I have reamed with a chuck on my lathe and the holes came out great. These cylinders will have a better finish than me boring on my lathe.
    .:: gdl357 ::.
  1. Multi Bit Drill Head
    By gregsm77 in forum WoodWorking Topics
    Last Post: 05-19-2021, 04:49 AM
  2. jgro Style CNC Build Journal
    By ignatz in forum Commercial CNC Wood Routers
    Last Post: 09-23-2005, 02:03 AM
  3. Drilling a perpendicular hole in drill rod material
    By ngr1 in forum MetalWork Discussion
    Last Post: 12-04-2004, 04:16 PM
  4. Router bit feed rates.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-28-2004, 05:54 PM
  5. What size of drill bit can be used for 1/2-10 acme tap?
    By starCNC in forum DIY CNC Router Table Machines
    Last Post: 04-29-2004, 11:36 PM
